Discussion topic: Wifi not working
Message posted on 20 Nov 2025 12:41 AM
Wifi not working
Message posted on 20 Nov 2025 04:00 AM
Re: Wifi not working
@Nuneaton2000
Making such threats on here is pointless. You aren’t communicating with Sky. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
You can't contact the ombudsman until the full complaints process has been exhausted.
You've posted after midnight so it may be essential overnight maintenance taking place.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
