Discussion topic: Wifi not working
This message was authored by: Londonchiz
Wifi not working
Light on box is on, check done here says no issue with connection but wifi isnt working.
Re: Wifi not working
@Londonchiz
There’s a possibility the current heavy rainfall may be causing some broadband issues.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
