Discussion topic: Wifi not working
Message posted on 12 Nov 2025 08:10 AM
Wifi not working
Message posted on 12 Nov 2025 08:18 AM
Re: Wifi not working
@Jessica-Stan wrote:
But today nothing is working!
@Jessica-Stan
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
