Discussion topic: Wifi not working
This message was authored by: Ben240
Wifi not working
Wifi not working, voice light on router Amber
Re: Wifi not working
@Ben240
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
