Discussion topic: Wifi not working
This message was authored by: KerriThompson
Wifi not working
Sky wifi box isn't working
Re: Wifi not working
@KerriThompson
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
