Discussion topic: Wifi not working
This message was authored by: Pleasehelp12
Message posted on 25 Oct 2025 12:50 AM
Wifi not working
I am typing in the correct password but the WiFi is still not working
Find out more
Message posted on 25 Oct 2025 05:38 AM
Re: Wifi not working
You haven't said what your issue is so if you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
