Discussion topic: Wifi not working
This message was authored by: IRWARRIORS
Message posted on 18 Oct 2025 01:40 PM
Wifi not working
Hello my wifi has just stopped working . The test shows everything is ok but no wifi. The hub shows 3 Green lights. Last time it went down it took you 4 weeks to fix and i work from home. You finally realised after 4 weeks it needed a BT engineer to send a new connection through. I need this sorting out asap.
Find out more
Message posted on 18 Oct 2025 01:52 PM
Re: Wifi not working
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
