Discussion topic: Wifi not working
Message posted on 26 Sep 2025 12:56 AM
Wifi not working
My WiFi is not working and my account is showing the balance has been paid on the 17th of September I would appreciate it if you give any knowledge as to why this is ASAP.
Message posted on 26 Sep 2025 01:02 AM
Re: Wifi not working
Are you in Feltham by any chance? A few of us have no internet here
Message posted on 26 Sep 2025 05:17 AM - last edited: 26 Sep 2025 05:24 AM
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
