Discussion topic: Wifi not working
Message posted on 13 Sep 2025 02:14 PM
Wifi not working
My wifi is not working. 2 orange lights on. Internet and voice
Message posted on 13 Sep 2025 02:40 PM
Re: Wifi not working
@Charliee
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
