Discussion topic: Wifi not working
This message was authored by: Rusha07
Wifi not working
My power supply seems to be working fine. However, the wifi is not working. All 4 lights on the modem is not switching on. The power light is swtiched on but the internet light does not get switched on.
Re: Wifi not working
@Rusha07
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
