Discussion topic: Wifi not working
This message was authored by: PK15274
Wifi not working
My wifi not working
Re: Wifi not working
@PK15274  If you mean your broadband service is down it should be noted Open reach, the network operator, tend to do maintenance overnight so as to keep disruption to a minimum.
If your service is still down later to day first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: Ace3
Internet still not working
@Ace3 if tge issue was overnight maintenance your servicecshould be bsck by now if it isnt then you have an outsge.
