Discussion topic: Wifi not working
This message was authored by: Talia891
Wifi not working
My WiFi is not working but the checks says its fine
Re: Wifi not working
@Talia891
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
▪️I AM NOT A SKY EMPLOYEE ▪️
