Discussion topic: Wifi not working
Message posted on 10 Jun 2025 11:22 AM
Wifi not working
My internet hasn't being working since 2 days now... the middle light kept blinking orange.. i have reset nd reconnected many times still the same.
- Its so annoying i'd to spend additional cash to get my children anoder internet to study nd watch tv.
Message posted on 10 Jun 2025 11:26 AM
Re: Wifi not working
@Zang
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
