Discussion topic: Wifi not working
Message posted on 28 May 2025 08:04 AM
Wifi not working
Our sky tv stopped today and now our wifi is not working, despite us still paying for it !
Message posted on 28 May 2025 08:10 AM
Re: Wifi not working
@Stephaniemckay
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
