Discussion topic: Wifi not working
Message posted on 07 Mar 2025 08:15 AM
Wifi not working
Hello, my Wi-Fi has been down now for the last 3 days. It keeps flashing in and out of Wi-Fi so the Wi-Fi comes and it goes. Please can we get this sorted ASAP as is very frustrating
Message posted on 07 Mar 2025 08:25 AM
Re: Wifi not working
@Lexielunar
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
