Discussion topic: Wifi not working
Message posted on 13 Feb 2025 11:07 AM
Wifi not working
Wifi keeps dropping out, wifi checker says it's ok but orange light on hub. Have had 2 engineer appointments and problem still the same - not getting what I pay for!
Message posted on 13 Feb 2025 11:43 AM
Re: Wifi not working
@Missguerin
In addition~
▪️This link providers information about the coloured lights on the various hubs
