Discussion topic: Wifi not working
Message posted on 28 Jan 2025 10:56 AM
Wifi not working
My WiFi has stopped working I have reset it but still no connection. Currently working from home so need wifi
Message posted on 28 Jan 2025 11:47 AM
Re: Wifi not working
@Rachel167
The lines may be busier than usual due to the damage and disruption caused by Storms Éowyn and Herminia which will also impact any potential Openreach visit.
