Discussion topic: Wifi not working
This message was authored by: Anne1909
Message posted on 17 Jul 2024 11:44 AM
Wifi not working
Hi;
my hub will only connect to thing in the same room as it.
i cannot connect it to my television in the other room (i live in a very small bungalow) the hub is out in the open.
please may you advise?
Find out more
Message posted on 17 Jul 2024 01:05 PM
Re: Wifi not working
@Anne1909 if your bungalow has solid internal walls WiFi is always going to be challenging otherwise the issue coukd also be interference from your neighbours' networks.
