Discussion topic: Wifi not on app
Message posted on 12 Jun 2026 01:48 PM
Wifi not on app
Getting a new hub as going full fibre but there is no WiFi on my sky sky app. Will it matter
Message posted on 12 Jun 2026 01:50 PM
Re: Wifi not on app
What do you mean by there is no WiFi on
the app, do you mean you don't see the broadband section ?
Message posted on 12 Jun 2026 02:09 PM
Re: Wifi not on app
I all I see is broadband shield and macfee
Message posted on 12 Jun 2026 02:24 PM
Re: Wifi not on app
@dogsathome do you mean the hub is not showing in the My Devices section of My Sky?. If your connection isnt live that is normal it should get populated once the connection is live.
