Discussion topic: Wifi not connectngi
This message was authored by: SandroSoldado
Message posted on 25 Mar 2026 06:28 PM
Wifi not connectngi
Had full fibre fitted today and new router.
Can only connect to wifi by using the QR code on the password card. If I try to connect manually for printer, TV, laptop etc the password is rejected. Any suggestions welcome thanks
Find out more
Message posted on 25 Mar 2026 07:44 PM
Re: Wifi not connectngi
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
