Discussion topic: Wifi not connecting
This message was authored by: Azra1
Message posted on 14 May 2026 10:39 AM
Wifi not connecting
The router is switched on. Ive run the checks via the app it's showing as everything is fine. The wifi is not searchable on any device therefore cannot connect.
Find out more
Message posted on 14 May 2026 01:19 PM
Re: Wifi not connecting
If none of the devices can see your network then try a reboot of your broadband hub then try again after giving it 5 minutes to finish loading back up.
