Discussion topic: Wifi not connecting
This message was authored by: Lcolley
Wifi not connecting
On hub green light on power & wifi, orange light on internet & voice
i cant connect to wifi on any device
Re: Wifi not connecting
@Lcolley
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
