Discussion topic: Wifi not connecting
This message was authored by: Lovepreet4
Wifi not connecting
I have issue with my wifi since yesterday as it is not working. Sometimes internet light gets blinking and than again it goes off.
Re: Wifi not connecting
@Lovepreet4  So it is not your Wi-Fi that you are having issues with it is your broadband you are having issues with which is a differerent matter.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
