Discussion topic: Wifi network not visible
This message was authored by: Barneyjl
My network doesn't show up when searching for it on my phone or any other device, so it's impossible to connect
Re: Wifi network not visible
@Barneyjl whst lights sre showing on the hub (see https://www.sky.com/help/articles/hub-lights-explained-start)? If you are some distance from the hub try again in the same room. If its a replacement Sky Max hub. Sky may have switched the hub to  use your old hub's details.
