Discussion topic: Wifi lost
This message was authored by: Jac39
Wifi lost
WiFi has dropped out, broadband says it's good but all my devices won't connect. Sky hub has a white light so should be fine. It's like it has stopped working as it should
Re: Wifi lost
@Jac39
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Avatar for Jac39
Re: Wifi lost
Nothing worked using sky. I isolated for an hour then turned on again but that did nothing. In the end I unplugged the box and left it over night. When I plugged it in this morning everything worked fine. Must be an issue with the sky max hub not being able to run 24/7
Re: Wifi lost
@Jac39 It's a possibility that, longer is better the off is trying to stear you down another server route, but then again the server may have been spotted as an issue and fixed asap, just no way off knowing that fact!
