Discussion topic: Wifi lagging slow horrendous
This message was authored by: Rainypinks
I've swopped from Virgin to sky , sky is so laggy slow , I've got tripple the amount I had with virgin , I've done all the tests and it said it's fine I have a small room at the front and it's impossible to get wifi in there , i wish I didn't change ,
It's horrendous
Re: Wifi lagging slow horrendous
It's horrendous
@Rainypinks
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
