Discussion topic: Wifi keeps stopping
Message posted on 26 Mar 2026 11:14 PM
Wifi keeps stopping
I am writing to formally raise a complaint regarding my broadband service, which has been extremely slow and frequently stops working over the past few days.
I work from home and rely heavily on a stable internet connection to carry out my job. Unfortunately, the current service has made it very difficult to work effectively, with repeated disruptions and poor speeds throughout the day. This situation is not acceptable, especially given the importance of a reliable connection for my work.
I would appreciate it if you could urgently investigate this issue and provide a prompt resolution. Please let me know if there are any checks I should perform on my end, or if an engineer visit is required.
I look forward to your swift response and a clear timeline for resolving this matter.
Kind regards,
Helena Ferreira
Message posted on 27 Mar 2026 05:28 AM - last edited: 27 Mar 2026 05:45 AM
Re: Wifi keeps stopping
You aren't making a complaint on here. It doesn't seem you have reported your issue to Sky yet. You also haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
