Discussion topic: Wifi keeps going off
Message posted on 02 Sep 2026 03:08 AM
My wifi keeps going off and back on, anyone else had this issue?
Message posted on 02 Sep 2026 03:14 AM
Re: Wifi keeps going off
Mine seems to be down in Sheffield
Message posted on 02 Sep 2026 05:18 AM
@ChloeDavies @alisonmanic
When there are broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Message posted on 02 Sep 2026 07:26 AM
It also went down at half 7 last night, then half 1 this morning, had to turn it off and back on and reconnect my sky extended again on app
Mine Rotherham
Message posted on 02 Sep 2026 07:28 AM
@ChloeDavies
Firstly it’s worth pointing out that Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Message posted on 02 Sep 2026 07:34 AM
Tried the sky app service checker, says the speed to your home is poor then when I test it, its saying sorry our tests are currently unavailable, been trying since half 7 last night
