Discussion topic: Wifi keeps going down
Message posted on 31 Oct 2025 07:00 PM
Message posted on 31 Oct 2025 07:05 PM
Re: Wifi keeps going down
@AmieZhou
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
