Discussion topic: Wifi keeps dropping
This message was authored by: SamanthaRankine
Wifi keeps dropping
Hi, my WiFi keeps dropping out constantly. It connects and then keeps disconnecting. I'm working from home and I can't have this keep happening.
thanks
Re: Wifi keeps dropping
@SamanthaRankine
Broadband and Wi-Fi are different. Broadband is the internet connection provided by your ISP (Sky), Wi-Fi is the wireless connection between your hub and devices.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault that just affects your address).
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
