Discussion topic: Wifi keeps dropping
This message was authored by: No-Gmail
Wifi keeps dropping
Wifi keeps dropping and reconnecting in the Maidstone area when i ran a diagnostic check it states everything is fine??!!
Re: Wifi keeps dropping
@No-Gmail
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
@No-Gmail
Was it this line test that you ran:
