Discussion topic: Wifi keeps dropping out
This message was authored by: John_McIntyre
Re: Wifi keeps dropping out
@John_McIntyre is it a WiFi or broadband issue. The two are different and you nedd to identify which it is most easily done by looking at tge lights on the hub https://www.sky.com/help/articles/hub-lights-explained-start when the issue happens. If the briadband connection is dropping then you need to report the issue to Sky.
However if the issue is poor WiFi in your home you may nedd a booster.
