Discussion topic: Wifi keeps dropping out rang sky and they say its good
This message was authored by: Deanwarner
Wifi keeps dropping out but Dky say nothing wrong.
Re: Wifi keeps dropping out rang sky and they say its good
@Deanwarner
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This message was authored by: Kate3871
I'm having the same issue.. been happening for the past 40 mins in south west London
@Kate3871
So the above advice still applies to you too (as it also did back in October when you posted).
