1
This discussion topic has been answered Discussion topic: Wifi keeps disconnecting
This message was authored by: Orkida
Hi team
today the wifi connection is horrible- breaking every 10 min especially in last 2 hrs.
please check what the issue could be.
thanks
Orkida
This message was authored by: Me134 Answer
Re: Wifi keeps disconnecting
@Orkida wrote:
Hi team
thanks
Orkida
We're only other customers here, like yourself.
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
@Orkida wrote:
Hi team
thanks
Orkida
Not a Sky employee
