Discussion topic: Wifi keeps disconnecting
This message was authored by: Orkida
Message posted on 14 Jun 2026 04:23 PM
Hi team
Could you please check why wifi keeps disconnecting?
when i test it in mysky app shows it is good but i see in the black box signal is red. I switched it off, and back on but didn't fix it. Came back for few min but then disconnected again.
thanks for checking
Find out more
Message posted on 14 Jun 2026 04:26 PM
Re: Wifi keeps disconnecting
This is a customer helps customer forum so when this happens what light are lit on your hub ?
