Discussion topic: Wifi keeps cutting off
This message was authored by: Leonar1979
I've run all the checks and says no issues in the area or my hardware but has been disconnecting for 10 mins now
Re: Wifi keeps cutting off
@Leonar1979
If it's not back on by now use the below link to check to see if there are any problems or outages nearby
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
