Discussion topic: Wifi isues
Message posted on 03 Apr 2026 04:38 PM
Wifi isues
Wifi keeps disconnecting
Message posted on 03 Apr 2026 04:48 PM
Re: Wifi isues
@bigneilly78
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
