Discussion topic: Wifi issues
Message posted on 05 May 2026 12:09 AM
Wifi issues
Message posted on 05 May 2026 05:04 AM
Re: Wifi issues
@Mason4
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
