Discussion topic: Wifi issues
Message posted on 12 Apr 2026 06:43 PM
Wifi issues
Hello, hope you're well. We have now been in our home for over a year and forever get WiFi issues, I will be cancelling this unless it can be solved today.
Message posted on 12 Apr 2026 06:47 PM
Re: Wifi issues
@Yasmin+DK
Threatening to cancel on a public forum is pointless and demanding it be resolved today, a Sunday, is totally unrealistic.
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
