Discussion topic: Wifi issues
Message posted on 03 Mar 2026 03:16 PM
Wifi issues
Hi Over the last few days we are getting intermittent internet connections. It seems more than usual. WiFi test is not true to what is available on mobile or ps5 connection. Nothing has been moved or changed in the set up. Please advise
Message posted on 03 Mar 2026 06:36 PM
Re: Wifi issues
@David3111 Depends on what test you are doing, is it this one below!
Try running the line test here to see if any faults are found:
