Discussion topic: Wifi issues
Message posted on 18 Dec 2025 05:40 PM
Wifi issues
Message posted on 19 Dec 2025 08:10 AM
Re: Wifi issues
@Leanne124 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
