Discussion topic: Wifi issues at home
Message posted on 06 Jul 2026 10:38 AM
Wifi issues at home
hi the apps says everything is ok, but i can not comment to the wifi.
any suggestions?
Message posted on 06 Jul 2026 11:06 AM
Re: Wifi issues at home
@ChrisLord First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 16 Jul 2026 04:39 PM
Every time we use internet we keep getting buffering
Message posted on 16 Jul 2026 04:45 PM
@Nana16 wrote:Every time we use internet we keep getting buffering
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
