Discussion topic: Wifi issue
This message was authored by: Leenalou
Wifi issue
I am working from home and can't connect to my wifi, it has been fine for the last hour and all of a sudden gone off, it says connection has dropped and I can't get it back on!? I've gone through the let's fix it but its not fixing!
Re: Wifi issue
@Leenalou
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
