Discussion topic: Wifi issue
This message was authored by: Bsd
Wifi issue
I have some weird Chinese vendor connected to my devices and my wifi doesn't work
Re: Wifi issue
@Bsd
You might want to change your wireless password:
https://helpforum.sky.com/t5/Broadband-Talk/How-to-change-your-Sky-Wi-Fi-password/ba-p/2673599
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
