Discussion topic: Wifi is not working
This message was authored by: MattMiller95
Wifi is not working
Hi,
I've run tests which says my hub and area has not issues but this is incorrect as it hasnt worked all morning and has orange lights on it.
I've restarted the router and nothing changes. I need wifi to work from home so this needs rectifying please.
I've had no issues in the past 18 months and as soon as I renew I have an issue. Please look into this ASAP.
Re: Wifi is not working
@MattMiller95
I'm not sure what tests you ran so apologies if you have already tried these:
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
