Discussion topic: Wifi is down
Message posted on 28 Jul 2026 11:43 AM
Wifi is down
Run tests it says everything is good and no faults in royston herts area but wifi isnt working and I dont know what else to try.
Message posted on 28 Jul 2026 12:11 PM
Re: Wifi is down
@blueangel85
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
