Discussion topic: Wifi is down
Message posted on 07 Aug 2025 07:19 PM
Wifi is down
We have had issues with our sky hub over the last week or so.
It would work for anlittle while then our connection will drop randomly.
I have reset it quite a few dozen times until it work for a temporary amount of time.
Today at around 19:00 it dropped yet again but this time it's not reseting properly. The WiFi indicator is off and the Internet indicator is constantly shining in red.
I've tried all I can do being a PC nerd but I believe I can't fix this issue and that our sky hub might require a servicing.
please contact us at your earliest convenience as we don't have access to our WiFi at the moment and from what it looks like for the rest of the day..
Best regards,
Pavlina
Message posted on 07 Aug 2025 07:33 PM
Re: Wifi is down
No one will contact you. You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
