Discussion topic: Wifi is down
This message was authored by: ShaneBlake
Wifi is down
The app is telling me my WiFi is working and all is fine. But I have no WiFi, the light is flashing red on the hub as it tries to connect it briefly got sorted via the app earlier this evening but now it's completely not working
Re: Wifi is down
@ShaneBlake
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
