Discussion topic: Wifi is down
Message posted on 18 Jul 2024 03:12 PM
Wifi is down
My wifi is down and cant get internet or television
Message posted on 18 Jul 2024 03:57 PM
Re: Wifi is down
@WillPol Is your router black or white? What colour are the lights on the router?
Message posted on 18 Jul 2024 04:02 PM
Re: Wifi is down
Hi it's a black router,
the power light and wifi light are green but internet and voice lights are off.
Message posted on 18 Jul 2024 04:24 PM
Re: Wifi is down
@WillPol Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 18 Jul 2024 05:29 PM
Re: Wifi is down
Mine is as well
Message posted on 18 Jul 2024 05:36 PM
Re: Wifi is down
Mine is gone too. The sky app directs me to a number to call but number doesn't connect to anyone or anything. Typical, useless crap from Sky
Message posted on 18 Jul 2024 06:24 PM
Re: Wifi is down
@Jason105Is your landline working as it seems to be if you have called Sky. If you can't get through on the number just dial 150 on your landline and just stay on the line even if they want to send you a text for here.
