Discussion topic: Wifi is connected but not working
This message was authored by: Rich159
All the devices are still connected to sky broadband but the WiFi is just not working. I cannot search anything on google or use any app that needs internet. On the sky broadband box the power and wifi light are green but the internet light is repeatedly going off then flashing amber. This has been happening for the past couple days
Re: Wifi is connected but not working
@Rich159
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
